1967 Shelby End Caps Fasteners
Started by nightmist67, January 12, 2023, 07:40:40 PM
nightmist67
Need a full set of correct RBW fasteners to install a pair or original 1967 Shelby fiberglass fender extensions (end caps).
greekz
You might check the AMK catalog if you cannot find some originals.  His bolts are really close to originals.
SFM 6S1134  '67 GT-350 #2339
nightmist67
Are you referring to the AMK Products Part No. B-11540 (5/16 x 18 x 15/16 HX .88 CONI SEMS LP "RBW" Cadmium/Wax Finish)?
Quote from: JD on January 13, 2023, 03:22:23 PM
Link, scroll down on link...
https://www.amkproducts.com/i-kits/ford-individual-fastener-kits/?year_=1967&model=Mustang&category=Body
See attached...the F-3292 Kit and parts
Hope this helps
That is the correct bolt and finish however technically RBW was the typical makers mark on the bolt head and not SEMS. A small detail for those who want to be most correct.
