68 Speedometer drive gear
Started by shelbydoug, January 31, 2023, 12:13:14 PM
Can someone advise as to which is the correct drive gear that goes into the transmission for 3.50 gears?
I think it is the white one but I'm not sure anymore?
Are you speaking about a 1968 GT350?
C4OA-A id
P no C4OZ-17271-A
Color RED (solid)
21 Teeth
Now if your tires are not stock, then you need to adjust
3.89  rear  judging by chart white or yellow should work for you
Oye! Questions!
Actually I'm not running anything stock so I'll be busy juggling stuff around.
Don't confuse me more then I already am, or will be or strive for or...  ::)
Is it possible for your headache to actually explode?
Thanks for the chart Phil.
Pete. I forgot what I have in there now. I have to pull it out? I want to say it's a white gear but I vaguely remember a red gear but that might be from the bar at Mardi Gra and drinking Cosmos?
