69 GT500 junction block
Started by kasearch@ix.netcom.com, August 30, 2023, 03:50:31 PM
I am NOT an electrical guy and I need some help.  First, can someone post a picture of an installed and wired junction block for me. Second, my guy informed me that he needs a fused link wire that attaches to the junction block on my car. If so, where do I obtain the correct gauge, color and design for my application?
We burnt up the fuseable link in one of the alloy Metal reproduction wire looms. It was part of the wire loom and about the last 4-6" of the loom. Don't know that they are sold separately (believe they are not) but we were able to get one and replace the other and rewrap the loom to hide the repair
Here are some pictures. Already posted them on another site so had them uploaded already.
Quote from: kasearch@ix.netcom.com on August 30, 2023, 03:50:31 PM
What harness ? Convertible top power?
Thanks Jeff. So the fuse-able link is part of the main harness loom?  I got my harnesses from Alloy Metal but don't remember seeing the fuse-able there.
Quote from: kasearch@ix.netcom.com on August 31, 2023, 08:57:21 AM
If I recall correctly its just part of the loom, not even a lump like some of them have
Convertibles have separate fusible link, fastbacks no
Quote from: TLea on August 31, 2023, 04:51:58 PM
Yes depending on which type of Shelby - one or two fusible links. Guess we should have asked which he was looking for before this point
I don't recall a fusible link other then the one for the convertible top power. You had me second guessing myself so I went off the wiring schematics in the 69/70 Shelby shop manual supplement . I couldn't find a fusible link in any of the schematics. If I missed it can you point it out.
Here is the illustration from the factory manuals for the convertible top harness with its fusible link marked in the schematic. Unless I overlooked it I could not find another marked "fuse link" on any of the other factory or Shelby harness's.
Quote from: Bob Gaines on August 31, 2023, 05:12:04 PM
For the other main loom I was going off the fact that at least the reproduction loom (Alloy) has one and that the poster may have burned his up on his Alloy loom which based on private conversations he apparently did.
Will try and find some time to look through the factory wire diagram book to see if its identified on the factory loom in that document
Maybe you're talking about the resistor wire?
Quote from: TLea on August 31, 2023, 05:45:51 PM
Alloy referred to the section we burnt up and they sent us as a fusable link from my recall. Not sure why there would be a resistor wire built in at the end of the loom in the area shown in the pictures I posted earlier.  Don't understand being placed there why they would have wanted to not want full voltage but not an electrical engineer by a long shot
Quote from: J_Speegle on August 31, 2023, 05:49:00 PM
I am not sure why there would be a fusible link at the end of the loom in the area shown ether. All of the circuits on the headlight harness ether run through the fuse box or are on various breakers. The convertible top wire harness does not get its power through the fuse box or a breaker which is why it uses the fusible link for that application.
Quote from: Bob Gaines on August 31, 2023, 06:21:46 PM
For this example would have to ask Alloy. Made allot of smoke (as expected) is just a second to two ::) and there was a junction between that section of wire and the rest of the loom. It saved out b**s from having to replace the whole loom
