3259 Screw Gasket
Started by csxsfm, May 06, 2023, 06:55:42 PM
csxsfm
Anybody have a recommendation from experience for the gasket that seals the 3259's fuel bowl screws?
TA Coupe
Contact Drew from on the forum here.
         Roy
If it starts it's streetable.
Overkill is just enough.
Rickmustang
Drew is Air Fuel Spark on IG or FB.
trotrof1
texas swede
I used O-rings and the problem was solved.
Texas Swede
67350#1242
QuoteI used O-rings and the problem was solved.
Texas Swede
+1  Small O-ring and nylon gasket.
