67 GT500 temperature gauge
Started by Rex, May 07, 2023, 05:29:21 PM
Rex
How accurate accurate are the temperature gauges on a 67 GT500?
With everything working adjusted and working as designed they do what they were designed to do. Indicate a range in relationship to extremes Since there are no numbers nor is the size large enough to do so. Just like any Mustang with that style gauge.
Guess there is another problem or issue your having
The gauge works fine but you need to use an original Autolite or the Motorcraft replacement sensor. Aftermarket senders will read abnormally high.
Rex
That’s what I have going on. Any NOS senders out there?
Quote from: Rex on May 07, 2023, 08:03:59 PM
That's what I have going on. Any NOS senders out there?
They are few and far between. Post a wanted ad. Check Ebay.
Rex
The one you want to have the best chance at success will be marked ether Motorcraft or Autolite and have a red insulator.
Rex
