Repo Autolite voltage regulator question
Started by 1175, May 26, 2023, 05:50:56 PM
greekz
Quote from: Royce Peterson on May 31, 2023, 02:15:11 PM
Quote from: greekz on May 27, 2023, 07:12:40 PM
Just for grins today I checked the voltage output on both cars:
1966 GT-350, with mechanical voltage regulator and rebuilt alternator by Dead Nuts On.
12.8 volts @650 rpm
15.8 volts @1300 rpm
1967 GT-350, with solid state voltage regulator from Virginia Mustang and rebuilt alternator by Dead Nuts On.
14.5 volts @750 rpm
14.5 volts @1250 rpm
At least with my two cars, the solid state voltage regulator is more consistent.  Not sure this data means much, but thought I would share.
Greek
15.8 volts is way too much. 13.7 is better long term. 14.5 seems a bit high too but might be OK if you don't drive much.
Thanks for the suggestion.  I may be replacing the old mechanical with a solid state.  Also, my battery is 10+ years old and may be weak requiring more voltage.  What I need to do is check it after a drive and see what the numbers are.
SFM 6S1134  '67 GT-350 #2339
12.8 volts @650 rpm
14.5 volts @750 rpm
Greek
+1 . Yes 15.8 is too high factory specs upper limit is stated as 15.1 .
rkm
While we're talking about this, I have an MSD box and distributor. Do I need a ballast resistor?
Quote from: rkm on May 31, 2023, 04:19:59 PM
Not for the distributor because the MSD unit requires a full 12V. Otherwise strange things that are not good happen.
