Correct emergency flasher for 69 Shelby with solid state sequential control
Started by TS69GT500, June 06, 2023, 10:59:38 AM
TS69GT500
Just purchased a solid state sequential taillight control board from Branda.
I also purchased the required turn signal flasher.
Upon reading the instructions it is recommended to replace the emergency flasher however
the instructions show an old Ford part number.
Does anyone have a current manufacturer and part number for this?
TonyS
The original flasher assembly had  C9WY Ford part number. These are hard to find and usually run over a $100
A "323" flasher is a replacement for a multi bulb system and should work. You can Find these on eBay. Do not use a replacement for a 323, only a 323
69 GT350 Vert
Vic Yarberry makes super high quality replacement sequencing systems for shelbys.  I've had one for 5 years and it works great.  He might be able to help as well.
http://www.thuntek.net/cougars_unlimited/
Quote from: 69 GT350 Vert on June 06, 2023, 03:34:57 PM
I bought a LED setup from Cougars unlimited when the system came out many years ago(waited for it). The ONLY way to go if you drive your car on the street. Much brighter than the factory bulbs when had me in a few near misses over the years and I had actually had people pull up next to me and say they couldn't see my brake lights good during the day.
