Vacuum schematics
Started by Thanx2cs, July 29, 2023, 09:55:38 PM
Thanx2cs
Looking for vacuum schematics for my 68 GT500 w/automatic.  Where to look?
Quote from: Thanx2cs on July 29, 2023, 09:55:38 PM
Major Mustang vendors like National Parts Depot sell a condensed version of the Mustang specific vacuum schematics.
Are you looking for engine or everything?
Thanx2cs
Yes,
I thought it was on your site CS.
Thanx2cs
I realized I did not answer your question.
Yes to engine and everything.
I am going to assume you have the correct intake fittings, vacuum advance and vacuum tree on the thermostat housing:
Vacuum tree top port to carb is yellow stripe
Vacuum tree center port to distributor vacuum advance is green stripe
Vacuum tree  bottom port to front intake fitting is red stripe
Brake booster, vacuum modulator for trans and tilt steering are off rear intake fitting
Smog anti- backfire canister goes to front intake fitting (I think)
If you have AC you will need the diagrams
