1968 GT350 oil breather hose routing
Started by Beeler422, August 16, 2023, 01:11:10 PM
Beeler422
Where does the hose from the breather cap on the driver side connect to?  I've searched around but can't find a picture or a description.
Corey Bowcutt
If I understand the question, and not sure I do, it connects to a nipple under the air cleaner base behind the carburetor.
Corey
Beeler422
Isn't that where the pcv connects?
Sorry if i didn't word it right.  I'm talking about the oil filler cap on the driver side valve cover.  It has a nipple on it for a hose.
Corey Bowcutt
No the PVC goes to a nipple on the back of a spacer under the carburetor. (I think)
Beeler422
Oh sorry, I thought that was what you were referring to. I don't remember a nipple under the air cleaner.   I'll have to have another look.
Yes should be in the stamped steel base
These help??
Passenger side PCV while we're here and someone brought it up
Beeler422
#7
Perfect!  That's exactly what I needed.  Now I just need to find the fitting for it.  Anyone know where I can find the correct fitting?
Quote from: Beeler422 on August 17, 2023, 01:02:49 AM
The breather hose connection to the air cleaner base is made into the base, not a separate piece.
Beeler422
#9
Quote from: CharlesTurner on August 17, 2023, 01:15:14 AM
Ah OK.  I guess I need to take it off and have a better look.  At some point someone used some silicone and just closed it off.
So thar being said, anyone know where to find that hose?
68blk500c
it is reproduced and available through suppliers.
Beeler422
Quote from: 68blk500c on August 17, 2023, 08:51:01 AM
I've looked and can't find it.  Have a link?
