Smog equipment
Started by 98SVT - was 06GT, January 23, 2018, 02:26:03 AM
Just bought a 1966 Tbird with a 390. It's got the air pump all the hoses brackets heads etc. Is it usable/same as on GT500? I'm going to end up with my 428CJ in it so I won't need the emissions stuff.
Quote from: 06GT on January 23, 2018, 02:26:03 AM
The short answer is about half of it is the same. The other half is different. The alt adjusting bracket is different and most like the driver side smog tube.  The pulleys will all be different. You can also use most of the hoses. The 66 smog parts are completely different then 68-70 CJ stuff but the 66 smog parts will fit on the CJ engine the same way as on a 67 PI.
Think you'll find that little is usable especially if you take into consideration that there are a number of running changes during the production year for your Shelby so more differences (parts not matching) if you have, for example an early car than a later car but still only a few more incorrect parts.
