'65-67 Shelby/HiPo Engine Parts & Misc
Started by marvs289, August 07, 2018, 02:34:34 PM
marvs289
o Used Fans, A67, $600,  G4, $700
o Motorcraft Distributors, $350
o Rebuilt Original S2MS Carburetor, DC 755(5th week of May 1967), $1100
o Timing Covers, $125
o NOS Intake Valves, $20/each, Exhaust Valves, $25/each
o NOS Valve Springs (6), $25/each
o NOS Rocker Arms with Fulcrums, $275
o NOS Valve Spring Retainers, $250
o NOS Early FoMoCo PCV Valve, THREADED, $75
o Used K-H Disc Brake Porportioning Valve, $150
o NOS BF-601 Spark Plugs, box of 10, $100
o Original '65-66 Firewall Heater Delete Plate,  Last One
o NOS Intake/Water Pump Heater Delete Caps (2), $30
o Original C5AF-10A352-H Alternator Pulley, $125
o RARE '67 TE Heads Set Castings, 6M22, $1500, TESTED
o RARE '67 Rebuilt Set Non-TE Heads, 6M8, $2400
o NOS S1MS Sway Bar, SOLD
o 66 W-MO, 10 65, Radiator Top Tank Only, SOLD
o Heads- 3H15 Set Castings,Tested, SOLD
o C3 (1) Casting 4A14, $1000
o C8 Set Heads Non-TE 9K23, $1400
o C5 Distributors, Used $500, Rebuilt $625
o NOS Early C3 Timing Set, $425
(includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight, AND Thrust Plate)
o NOS Later C5 Timing Set, $325
(includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight)
o Aluminum Water Pumps, $400
o RARE Reman '65 Cast Iron Water Pumps, C5OE-B Repro Impeller $425
o Reman '66-67 Cast Iron Water Pumps, C6OE-A Repro Impeller $325
o NOS Autolite Bypass Hose, $40  Only 2 Left
o NOS Autolite NO Star Spark Plugs, BF-32, BF-42 $60 set
o NOS Piston Pins $80
o Used C5AE-A Crank Pulley, $40
o Used Rods, $500
o Used Rods with Used Std Pistons, $700
o NOS Boss 302 Rods, not numbered, $900
o NOS Std Pistons, SOLD
o Used Std Pistons, $400
o New Set Sealed Power 4.030" Pistons, $350
o NOS Oil Pump with Pickup, $150
o NOS HiPo/427 Autolite Dual Point Tune-Up Kits SOLD OUT
(Includes 8 NO Star BF-32 Plugs, (2) DP-5 Points, (1) DC-6 Condenser)
o NOS Gaskets, Head $125
o NOS Set Rocker Arms with Fulcrums, $275
o NOS Set Push Rods, $80
Prices do not include shipping from VA. I will combine shipping in the case of multiple purchases. Pictures upon request. Thank you
GT350Lad
6S373
6S1276
