P/S Cooling
Started by T-Bone68, January 21, 2018, 11:55:15 PM
T-Bone68
Hi All.  My 67 GT350 does not have the cooling loop on the power steering.  I thought all 67 GT350s and GT500s came with this.  I looked up the part # in SAAC registry and bought the cooler (P/N C6AZ-3D746-A, this one stamped C5AA-3D746C).
1) Am I correct that all 67s had this power steering cooler?  Or is it possible this was an option mine did not have from Shelby?
2) Assuming I should have it, any suggestions where to track down the additional hoses needed to install the cooling loop?
John
Quote from: T-Bone68 on January 21, 2018, 11:55:15 PM
John
John all regular production 67 Shelby's came with the powersteering cooler and lines. The correct cooler is marked C6AA. The C5AA has a different mounting bracket position. Finding correct looking hose to use in the cooling loop is a trick all you can typically find has a weave texture that shows through. The original was very smooth in appearance . Look around and if you can't find any click on my name and private message me . I can hook you up with some .
T-Bone68
Thanks Bob!  I'll track down a C6AA and see if I can find the right hoses
John
bhoulis
Ii one decides to go shopping for the cooler hose, what are the correct I.D. and O.D. Thanks. Brian
