WANT to buy - C6 transmission for my 428 CJ restoration
Started by asrassoc, February 15, 2023, 05:33:47 PM
asrassoc
Well as I dig deeper into the restoration of my 1969 428 CJ it appears that the transmission on her is not correct.
Looking for a PGB-AF1 (i think?) for a 1969 428 CJ Mach I.
Bigfoot
You need one with a cast iron tail shaft, and in R servo.
Probably $2000-$3000
RIP KIWI
RIP KIWI
asrassoc
Yep. Have the cast iron shaft. Just the wrong transmission housing and data plate.
Quote from: asrassoc on February 16, 2023, 07:12:07 AM
You may have to consider buying a entire CJ transmission tail shaft and all because the R servo is the rarest part and typically only found as part of a complete transmission.  I would not hesitate a second . Tail shafts are easily sold separately . I understand that the case is different so I would not buy a R servo unless I was buying the case it came in too.
azdriver
This transmission is for sale local to me. Not suggesting you use it due to broken case. Just posting for information. Not mine. Don't know the seller.
https://phoenix.craigslist.org/evl/pts/d/mesa-428cj-transmission/7581041811.html
Pat
asrassoc
Quote from: azdriver on February 18, 2023, 10:51:05 AM
Pat
Thanks Pat. I'l check it out.
68gtcoupe
mtdubvee
SFM 5S123
SFM 5S269
1967 GT350 #41 Raven Black 4 Speed
Marcus Aurelius
"Home of the "Amazing Hertz 3 + 1 Musketeers"
I am certainly not a Shelby Expert
asrassoc
Still looking for  a C-6 PGB-AF1 for a 1969 428 CJ Mach I introductory show unit restoration.
stephen_becker
I have one - PM me and I will take pixs and give you details - It does not have the rear tail shaft on it
