Hipo Harmonic Balancer Rebuild
Started by emccarty, January 12, 2025, 06:09:46 PM
emccarty
Is there a reputable rebuild service out there that can replace the rubber on my original 289 HiPo harmonic balancer?  Getting ready to rebuild my engine and would like to have this replaced before I have rotating assembly balanced.
Any help would be appreciated.
Thanks.
Ed
hertz1966
Hello,
I sent Damper Doctor two hipo balancers last month.  Cost was $180 each.  Turn around time was about a week.  Good experience.
Tim
    I would suggest making a template referencing the relationship between the hub crank key slot and the inertia ring timing marks before sending the damper off for reworking; so as to have a comparator when it returns.  ;)
emccarty
Thanks for the input.  Ill give damper doctor a call.
Ed
