1969 GT 350 carburetor diesel switch
Started by aboss4tg, August 18, 2018, 11:23:13 AM
aboss4tg
Motor is coming along and need information on the Carburetor. Does this have the diesel switch set up and was a spring attached to the carburetor for the throttle cable return?
Appreciate any help
Todd
69 GT 350 Hertz
66 Convertible C code
66 Fastback A code
88 Saleen
89 SSP
There is a spring that goes under the linkage (attaches to the throttle arm at the bottom) that goes rearward to the throttle bracket that attaches to the two rear carb mount studs, also holds the throttle cable in place also
No electric switch used at the throttle arm like on the Boss 302
Quote from: aboss4tg on August 18, 2018, 11:23:13 AM
Appreciate any help
Todd
No electric switch as mention. Here is a 69 GT350 carb shot from a vintage magazine that may help.
SNAKEBIT
What's this talk about a diesel? Is it just a switch in name only?
Waitin' for the day I get my first '70 Shelby convertible!
Quote from: SNAKEBIT on September 17, 2018, 05:06:36 PM
The term "dieseling" is also referred to as "run on" which is what the solenoid is designed to eliminate
https://www.merriam-webster.com/dictionary/dieseling
https://en.wikipedia.org/wiki/Dieseling
https://www.definitions.net/definition/dieseling
SNAKEBIT
Oh, I didn't know that. I have a lot to learn about engines.
