Shelby fiberglass hood springs
Started by 69mach351w, October 20, 2018, 01:25:27 PM
69mach351w
Are they smaller in diameter, smaller in length, not as many coils?  I know the tensil strength is not as much as metal hoods.
acman63
same length   , smaller wire  $17  for the small one.  these are for steel frame 65/66 GT350 Hoods
SAAC Concours Chairman
Quote from: 69mach351w on October 20, 2018, 01:25:27 PM
Which year Shelby Fiberglass hood are you asking about?
I don't think (?) the '67 Shelby fiberglass hood spring(s) is/are the same as the earlier year(s).
See attached below - the "smaller" on the right side of the image is the ALL fiberglass hood spring for '67's which is not what is shown in the top position of the above posted image.  Note the ends are different.
The spring on the left side below is the stock Mustang spring (maybe the same as the lower spring in the image posted above) used on the early fiberglass bonded to the metal frame of early '67 Shelby's.
To add to the discussion ,the 68,79/70 hoods used the regular Mustang springs . Someone else will have to answer if the 67 light spring would be strong enough to hold up a 68 or 69/70 hood without slamming shut with the slightest breeze.
