289 HiPo Engine Parts Cobra, Shelby GT-350
Started by marvs289, November 22, 2018, 05:31:42 PM
marvs289
o Fresh 0.010/0.010 Under Original HiPo Crankshaft, still has the orange paint, SOLD
o NOS '65-66 GT-350 WHITE Stripe Kit, one GT-350 decal missing, $150
o NOS '67 GT-350 WHITE Stripe Kit, $225
o NOS C8 HiPo Damper, $275
o NOS 65-66 Parking Lights, $250
o Rebuilt 3734S Fuel Pump, $400 (early Cobra I think)
o (1) C3 Casting, 4A14, Tested $1000
o RARE '67 TE Heads Set Castings, 6M22, Tested, $1900
o RARE '67 Rebuilt Set Non-TE Heads, 6M8, Rebuilt, Tested $2400
o RARE '67 Rebuilt Set Non-TE Heads, 6M22 7E8, $2200
o C8 Set Heads Non-TE 9K23, $1500
o Used Rods, Floated, $500
o Used Rods, NOT Floated, $550
o NOS Boss 302 Rods, not numbered, $900
o Used STD Pistons, $350
o New Set Sealed Power 4.030" Pistons, $400
o Used Fans, A67, Like New, $600,  G4, $700
o C5 Distributors, Used $500, Rebuilt $625
o Motorcraft Distributors, $350
o Rebuilt Original S2MS Carburetor, 755, $1250
o Timing Covers, $125
o NOS Valve Springs (6), $25/each
o NOS Rocker Arms with Fulcrums, $275
o NOS Valve Spring Retainers, $250
o NOS Early FoMoCo PCV Valve, THREADED, $80
o Used K-H Disc Brake Porportioning Valve, $150
o NOS BF-601 Spark Plugs, box of 10, $100
o NOS C8 HiPo Damper, $250
o Used C5 Damper, A5, $500
o Original '65-66 Firewall Heater Delete Plate, $75 Last one
o Original C5AF-10A352-H Alternator Pulley, $125
o NOS Early C3 Timing Set, $425
(includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight, AND Thrust Plate)
o NOS Later C5 Timing Set, $325
(includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight)
o Aluminum Water Pumps, $400
o VERY RARE Reman '65 Cast Iron Water Pumps, C5OE-B Repro Impeller $425 (used May-August '65 only)
o Reman '66-67 Cast Iron Water Pumps, C6OE-A Repro Impeller $325
o NOS Autolite Bypass Hose, $40  only 2 left
o NOS Autolite NO Star Spark Plugs, BF-32, BF-42 $60 set
o NOS Piston Pins $80
o Used C5AE-A Crank Pulley, $40
o NOS Oil Pump with Pickup, $150
o NOS Gaskets, Head $100
o NOS Set Rocker Arms with Fulcrums, $275
Prices do not include shipping from VA. I will combine shipping in the case of multiple purchases. Pictures upon request. Thank you
marvs289
Someone made an inquiry about HiPo Rods, but the email had no content. Please try to contact me again. Either here or at marvsmustangs@comcast.net  Thanks
Rohan
Hi, do you have a distributor for. 67 hipo dated January or February 67?
marvs289
Sorry, I don't have any with those date codes. Thanks
