Radiator restoration
Started by BGlover67, November 07, 2018, 10:12:06 AM
BGlover67
Can anyone recommend a place to work on a radiator of mine?  I have an NOS radiator, but it's for an automatic and I need it welded to be used for a 4 speed.
Thanks.
Brian R. Glover
Sapps Radiator in Garner, NC has done some for me in the past.
Quote from: BGlover67 on November 07, 2018, 10:12:06 AM
Thanks.
Brian,you are typically asking about factory stock details . I don't think the results will match your expectations. Based on you initial post you may not be aware that you are not going to typically make the automatic line fittings openings disappear completely unless you change the bottom tank. That is something that you will have to supply. That is not to say that working over the bottom tank to make it cosmetically invisible from the outside after repair couldn't be done if you had no other choice but that would be a lot of extra work for a skilled person.  It would be quite a coincidence that a radiator shop would have the correct factory 4 speed Ford bottom tank to use. If are just going to seal off by brazing or solder (no regular welding on the copper material) any good radiator shop should be able to solder or braze the openings closed. Given it will not be invisible anyway you could ether plug with plug fittings made for this procedure or less noticeable a Allen fitting that could be installed flush and covered over. The Allen fitting after sealing flush could be covered over with a bit of epoxy and painted to be less visible which could be done by you instead of a radiator shop. I don't see the advantage in a lot of extra effort to solder the fitting up if they are not going to completely disappear is why I am posting. FYI the Ford service radiators routinely came with the automatic cooler fittings that were plugged so that they could be used for both applications. Just thought I would mention this in case you were not aware.
BGlover67
Thanks Bob.  I wasn't sure if that were possible.  I do have two other original radiators, not in great shape, I'll try to use one of their  bottom tanks.
Brian R. Glover
TedS
Quote from: CharlesTurner on November 07, 2018, 11:28:50 AM
I believe it was Sapps that had the motto "A good place to take a leak". That always made me laugh.
If you use Sapps I would recommend not letting them paint it afterwards. This was quite a while back but mine came back with an excessive coat of gloss black.
Ted
  Ah, isn't the stamped-in part number for a 4 speed radiator different from an automatic car?  How about stating the numbers.
Quote from: roddster on November 07, 2018, 06:46:20 PM
Stamped in engineering number is on the side strap of Dearborn and Metuchen built car radiators. Given the owner we are talking about a solder on tag that can be changed to fit the configuration if necessary .
H2 for manual no A/C
J2 for early Auto No A/C (IIRC)
 Thanks JD. Now everyone can find this in the future.
Depends on when the radiator was made. 65-early 66 production had it stamped in the top tank while later only had the maker and date in the top tank metal while the application was identified by the add on metal tag as shown above. This was a San Jose detail so later cars have different details
It appears that you might be asking about a 67 radiator though year was not mentioned in the request.
Bossbill
My "2 67 WMO" extra cooling radiator is marked C7ZE T2.
It's a manual transmission radiator.
70 B302   6/6/70  0T02G160xxx
madeulook
Ditto's on the paint comment. I have never let the shops paint my radiators again after the first time. Way too much paint and not period correct.
Find an OS or NOS bottom - cures a world of hurt.
SFM5R-madeulook
1965 GT 350 Competition Tribute
1st. place pop vote Mid-Ohio
