WANT TO BUY , 1970 428 SCJ OIL PAN, C9ZE ,
Started by bobboss351, January 15, 2019, 06:00:27 PM
bobboss351
Looking for a 1970 428 scj original oil pan, the one looking for is a  428 scj C9ZE  short baffle oil pan,  must be good condition and have a legendable logo and a date code before June 1969,,, call or text 651 485 9832 , Bob Wilson, bobboss351@gmail.com,,,
RJ RESTORATIONS
Robert Wilson
701 FIRST ST
SUITE B
FARMINGTON ,MN
55024
Not just scj  but all 69 70 428 cjs  as well used this pan with the c9zz baffle. I sent a 69=70 short oil pan baffle to chris brown to have made since this part is much needed.
Shelbypat
You may know but just in case. The ford tooling 428 oil pan availible in the market has logo and 68 date coded
I know that but the good repo is a c60z pan 69-70 cjs use a windage tray so the oil pan baffle was smaller & spot welds lower in the pan.  We are only making the unique 69-70 baffle so u can change out the early baffle with the correct baffle if u have a 69-70 cj.  The baffles are being made now in a limited run.
