NOS Fender Mount Radio Antenna
Started by kingchief, February 15, 2019, 06:03:15 PM
kingchief
Hi! Anyone have an extra NOS or EXCELLENT condition front fender mount radio antenna???  For a '66 Shelby.
Thanks for helping if possible.
Cheers,
Steve
SFM 6S406
Hi Steve,
Have you seen this one?  The price is not horrible for as nice condition.  I do not know the seller.  Hopefully others will confirm it is orignal.
https://www.ebay.com/itm/ORIGINAL-FORD-1965-1966-MUSTANG-SHELBY-RADIO-ANTENNA-VERY-NICE-OEM-64-5-65-66/192818217553?hash=item2ce4dc8251:g:pdoAAOSw0yVcXJR7:rk:3:pf:0
Is the part number you are after C5ZZ-18813-A.  Do you have the Ford MPC to verify?  If not, I can check tonight.
kingchief
Hey Cory.  Thanks for getting back to me.  As you know, you and your group have been a GREAT help to me.
Yes, I was looking at this one.  It looks pretty good and hope others will comment.  The one on her now is a Ward but with a C7 marking and NO Ford marks on the cable...only Ward.  Looking to upgrade!!!  8) 8) 8)
Thanks AGAIN!!!
Steve
SFM 6S406
Quote from: 6s1640 on February 15, 2019, 06:22:46 PM
Hi Steve,
That looks like a nice antenna unfortunately it is the 67/68 style. 65/66 has the antenna mast not being able to collapse flush with the second mast section . It will typically stick up a inch or more from the second section. The 67/68 style will collapse flush with the second section as illustrated in the auction picture. FYI the 65 /66 style is the more common of the two for what ever reason so they typically come up more often then the 67/68 style like pictured in the auction. The correct ones are easy to spot at shows ,swap meets etc. once you are aware of the difference .
Quote from: Bob Gaines on February 15, 2019, 07:09:05 PM
Hi Steve,
Hi Bob,
I knew you would know the differences and the right style for 65/66.   Is C5ZZ-18813-A the right part number?  Will the NOS C5ZZ-18813-A  part be more like a 67/68?
Thanks for sharing.
kingchief
Thank you Bob.  Does anyone have a picture of the 65/66 style that Bob indicates???
Thanks in advance,
Steve
SFM 6S406
Hi Steve,
The Ford MPC shows the C5ZZ-18813-B as the service replacement for 65 to 68 Mustang.  So it is likely not the right one for 6S406 and is the later style.  I don't now about the C5ZZ-18813-A, but it is the same part number for the one Bob sent the link.  So I think you are after the -A version.
I do have a lead on another -A that I will send you in a PM.  You might be able to get a better price.
kingchief
Thanks so much Bob and Cory. Cory, please send to email...you have it. I see the difference now. If no go and not too late, I shall pull the plug on Mr. Turner's...UGH! Nice part though!
Cheers,
Steve
SFM 6S406
Hi Steve,
Bob, I am confused here. The eBay Link(s) seems to show a mast that doesn't collapse completely.
Is that the '66 or '67 style?
kingchief
This is the earlier style with the extra step at the top of the mast that Bob is referring to.  Although the box has a C7ZZ number on it, Charles Turner [judge and Shelby Forum member] says it may have been a very early replacement.
Best regards,
Steve
SFM 6S406
