Wheel Covers and Wheel Weight interference issue
Started by Corey Bowcutt, April 15, 2019, 08:26:03 AM
Corey Bowcutt
I mounted my stock steel wheels yesterday for the first time.  When I tried to attach the wheel covers I had an interference with the wheel weights.  I have to assume others have had this issue.  What is the best solution?  Are there thinner profile wheel weights?  Do folks use stick on weights in locations that will not interfere with the wheel covers?  Do you just put the weights on the inner side of the rims?
Corey
papa scoops
I think you are suppose to balance them with the wheel covers on, so one would assume we would put weights on back side? phred (covers in the trunk since day -1)
mr68shelby
Technical Letter No. 2 that covers the wheel balance issue says to place the weights on the inside of the wheel. Mike
Corey Bowcutt
Thank you guys.  What is technical letter #2?  How many technical letters are there and how can I find them?
There are 14. They are printed in the Registry
http://www.thecoralsnake.com/Warranty
service bulletins covered these areas:
Engine Noise transmitted through the radio
Wheel imbalance due to 1968 hubcap weight
State approval of shoulder harnesses
Flashing of Marchal Lights
Misleading engine code in GT500 serial numbers
Fuel Tank Removal
Identifying GT350 Starter motors
Modifiying The C8AE-9510-AE Autolite carb on GT500s
Operation of emergengy flasher
Eliminating sequential lights
Oval Air Cleaner modifications
Speedometer gear corrections
Special Paint colorcodes
Blinking Exterior Lights
Corey Bowcutt
Thank you Pete.  For those without a registry is there any other way of getting them?
chris NOS
i Would suggest to buy one , it's full off great infos and worth every $ you'll spend...
