Ammeter Wiring ?
Started by oldcanuck, January 15, 2020, 03:18:36 PM
rmarble57
Yes #23 has an insulator behind the terminal block.
Thanks for the tip however.
BGlover67
Quote from: Royce Peterson on January 18, 2020, 09:10:57 AM
Just in case anyone wants to make their own terminal block the Mil - Spec part number is MS27212-X-N
Where X = Diameter of the studs (terminals) on the block.
Possibilities:
MS27212-1-N = 6/32 UNC-2A
MS27212-2-N = 10/32 UNF-2A
MS27212-3-N = 1/4 -28 UNF-2A
MS27212-4-N = 5/16 - 24 UNF-2A
MS27212-5-N = 3/8 - 24 UNF-2A
MS27212-6-N = 8/32 UNC-2A
Where N = Number of studs on the terminal block
From the photos it appears to be MS27212-4-N (5/16-24 stud size). You could use any dash number, the parts installed by Shelby American appear to be made only from the ends of a T-block. So regardless of the length of the T - block you would only get two usable parts that were like originals.
Wow Royce, that was impressive.  I was able to find one immediately on ebay.  Do you have any idea who manufactured the shoulder harness retractors on '67s?
Brian R. Glover
DGSOH
Quote from: BGlover67 on January 18, 2020, 08:19:53 PM
Possibilities:
+1
oldcanuck
Guys,
Is there anything particular with the second or later variant, that I need to be aware of when hooking mine back up ?
Thanks again,
Bob
Bob
Knoxvegas, TN
Might be able to figure it out if you have pictures, especially if they show any cartouche mark of the maker.
Possibilities:
Quote from: oldcanuck on January 19, 2020, 08:08:13 AM
Guys,
Thanks again,
Bob
Does the first illustration in reply #2 help?
oldcanuck
Quote from: JD on January 19, 2020, 11:14:58 AM
Guys,
Thanks again,
Bob
Yes ..... perfectly.
Bob
Knoxvegas, TN
csheff
Is there a certain type of insulator that was used? Anyone make them?
#23
It appears to be 1/32" phenolic sheet, as would have been the case if you could find the Mil - spec unit new in the box. You can buy phenolic sheet under various trade names like Garolite for example:
https://www.mcmaster.com/phenolic-sheets
Quote from: csheff on January 20, 2020, 08:05:23 AM
Quote from: Royce Peterson on January 20, 2020, 10:38:20 AM
The https://www.mcmaster.com/phenolic-sheets examples don't look like the insulator that Shelby used. It was more like a thin piece of circuit board looking material. At least that is what it looks like to me.
Bob, circuit boards usually were / are made on phenolic / foil sheet. Phenolic runs in various hues depending on batch and grade. It tends to darken as it ages, much like bare wood.
There were cheap transistor radios with plastic circuit boards molded in every imaginable color. Those are not phenolic.
Another source of phenolic sheet is https://www.amazon.com/Online-Plastic-Supply-Phenolic-inches/dp/B081VR42MG/ref=sr_1_25?hvadid=78271487894049&hvbmt=be&hvdev=c&hvqmt=e&keywords=phenolic+sheet&qid=1579623720&sr=8-25
There are many grades and colors of phenolic from creamy white to tan to brown to black.
Quote from: Bob Gaines on January 20, 2020, 06:30:54 PM
Quote from: Royce Peterson on January 21, 2020, 11:25:01 AM
Not disputing your definition just disputing the look. I used the circuit board comparison because that is what it closest reminds me of older transistor board material.  Not plastic ones. It does not look any of the many examples in the link that you posted which is the reason that compelled me to reply.
