69/70 gt350 convert springs.
Started by shlb69, February 17, 2020, 11:02:29 AM
shlb69
:Looking for a set of orig rear leaf springs for a 70 gt350 convert. shlb69@aol.com 217 415 7748
Quote from: shlb69 on February 17, 2020, 11:02:29 AM
FYI the leafs are different length compared to a regular Mustang so you need the bottom 3 leafs (or the complete spring)and not just the bottom leaf like you can get away with transfering on a regular Mustang.
Quote from: Bob Gaines on February 17, 2020, 12:04:31 PM
Thanks I didn't know that and 3 being different. Is there a process that is called out anywhere you know on restoring my rear leafs? I got Eaton ones on it now and put the originals away. Gary
69 shelbys will be s9ms or c9zx on bottom flat unique leaf and only use 2 wraps with a white color code on front eyelet .
69 GT350 Vert
My early car (100) has 5RS68 stamped on leaf springs.  Nothing else.
Correct only on very early 69 shelbys along with some other unique early car only features.
Quote from: shelbymann1970 on February 18, 2020, 08:52:08 AM
Start a new thread Gary so others searching can benefit from the info as well .
