Ebay 1967 Upper Scoops with Red Lights, Original
Started by BGlover67, March 06, 2018, 11:14:20 AM
BGlover67
For the early '67 Owners our there. Tony Branda has you covered.
https://m.ebay.com/itm/1967-Shelby-Original-Used-Early-Fiberglass-Upper-Side-Scoops/232687839300?hash=item362d46a844:g:bNcAAOSw06xanUcO
BRANDA PERFORMANCE INC.
SHELBY & MUSTANG PARTS
*** PRESENTS ***
1967 SHELBY GT350 & GT500
"EARLY"
ORIGINAL / USED
FIBERGLASS UPPER SIDE SCOOPS
1-PAIR
NICE ORIGINAL/USED & VERY USABLE SHELBY SIDE
SCOOPS: 67-68 SHELBY EARLY FIBERGLASS UPPER
SIDE SCOOPS
SHELBY PART#'s:
RIGHT SCOOP:
S7MS-63230B62-A
LEFT SCOOP:
S7MS-63230B63-A
SOLD AS 1-PAIR / LEFT & RIGHT SCOOPS
EACH MADE of FIBERGLASS
EACH SCOOP, still has THEIR MOUNTING STUDS
...see pics!!!
THESE ARE THE EARLY PRODUCTION RUN
67 SHELBY UPPER SIDE SCOOPS,
CARS FROM SERIAL# 1-199
THESE EARLY 67 SHELBY UPPER SIDE SCOOPS
FEATURE the ROUND CUT OUT HOLE for the
RED MARKER LIGHTS
(RED LENSES & LIGHTS ARE "NOT" INCLUDED")
THESE EARLY SHELBY SIDE SCOOPS, need VERY LITTLE
ATTENTION... for BEING over 50 YEARS OLD
ALL MOUNTING STUDS are INTACT
ONLY a FEW AREAS have PUTTY
CORNERS & EDGES are PRETTY MUCH SOLID
...see pics!!!
JUST CLEAN UP / PREP. / FIT to your CAR / PAINT
CONCOURS RESTORATION ORIG. SHELBY: 67 SHELBY
EARLY FIBERGLASS UPPER SIDE SCOOPS
THESE 2 ORIG. SHELBY SCOOPS: 67 SHELBY EARLY FIBERGLASS UPPER SIDE SCOOPS
PICTURED, ARE The 2 ORIG. SHELBY - 67 SHELBY EARLY FIBERGLASS UPPER SIDE
COOPS you WILL RECEIVE
*** GENUINE ORIG./USED SHELBY: 67 SHELBY GT350 &
GT500 EARLY PRODUCTION FIBERGLASS UPPER
$1,067.50. No bids
Brian R. Glover
557
Out of curiosity I gotta ask,Is the scoop assembly itself the same as later scoops except for the light hole?Did they cut those out or were they molded that way?
Quote from: 557 on March 06, 2018, 11:56:56 AM
Yes , they are basically the  same. The description sure makes it sound easy. ;)  The hole is cut out and the bulb/lens base fiber glassed in. It looks like those scoops never had the base in them ever. Or you could go in reverse and fill the hole for use on a later car.
Shelby_r_b
Interesting.  The red lens isn't right; which I'm guessing was placed there for picture purposes.
...wonder what car they came from, as I'm guessing that there weren't service replacement scoops for lensed cars.  Thoughts?
Nothing beats a classic!
Quote from: Shelby_0022 on March 06, 2018, 02:50:15 PM
Interesting.  The red lease isn't right; which I'm guessing was placed there for picture purposes.
Given the scoops are out of historical context and modified they offer little in the way of historical information IMO.
cbrown
That's interesting,  I did not think my lights on the early car i had was just a cut out round circle.  I thought it had round circle with 2 notches across from each other that the red marker light went into and then turned.  I need to dig up old pics...
chris
Richstang
Quote from: cbrown on March 06, 2018, 03:25:02 PM
chris
like this?
1967 Shelby Research Group
www.1967ShelbyResearch.com
