Wiring List
Started by Shawn, March 24, 2020, 07:17:36 AM
Shawn
Here is the list of wiring I'll be purchasing from Pete for my 66 Hertz automatic.  To replace all wiring with exception of grounds do I have it covered in this list?
1966 alternator harness
1966 intake wiring/top of engine
1966 headlight harness
1966 tail light harness
1966 under dash wiring harness
1966 wiper motor - Are there more than one harness for the wiper motor?
Shawn
I believe there's another harness for the neutral safety switch for automatic cars.  This is the one that plugs behind the dash and has 2 connectors on the engine bay side for the switch.
On the wiper harness, there's a lead for the washer motor that you'll need to make sure is included.  There's an early/late style pump which determines what type of lead.
Also, depending on the build date, the emergency flasher wiring setup is either integrated into the main harness or an extra add-on harness.
Rbwiii
The integrated harness is not available thru Alloy. If your harness is the earlier version you will need to purchase the emergency flasher wiring harness/switch also.
