Fuel Line Fitting
Started by Greg, April 25, 2020, 09:27:08 PM
We're talking about this adapter right?
Greg
Shelby's and Fords from Day 1
Quote from: Greg on April 26, 2020, 07:13:17 PM
Thank you Bob, I will look at it.
    Greg I have a few original spares , I'll send you one.
NC TRACKRAT
Randy-Not for me, as there is one on 071 but, for the sake of posterity, can you share any information that would identify this part?  If not a part number, perhaps you could determine the external thread that goes into the carb and the internal thread that receives the fuel line fitting?
5S071, 6S1467
  The male end is 1/8th pipe thread( tapered) the other takes a 5/16ths flared tube end. It is actually a common fitting .
Quote from: gt350hr on April 27, 2020, 02:21:38 PM
+1. I actually bought at a hardware store, to add to Randy's comments the internal thread that receives the fuel line fitting is 1/2"-20.
To add- the original ones many times had the metal stamp of the " W" mfg trademark for Weatherhead .
NC TRACKRAT
My "lightbulb" just switched "on".  If I'm not mistaken, the same fittings are used in the lower tanks of radiators for C-4's to accept the cooling lines.
5S071, 6S1467
    Winner winner , chicken dinner!
Quote from: NC TRACKRAT on April 27, 2020, 05:17:18 PM
Taught me something today.Thanks. :)
OldGuy
The fitting that is used in the carburetor is probably brass (?) whereas the fittings that are installed in the radiator (from the factory) are steel-you know, the rusty ones.
Frank
OldGuy
The transmission cooler fittings that I was referring to are on a "66 radiator which look EXACTLY like the pictured fitting. The factory fittings that I have in my radiator are steel (or extremely magnetic brass).
Frank
NC TRACKRAT
OldGuy is right.  They look the same but the radiator ones are steel.  The radiator tanks are brass but the fittings are steel. Hmmmmm.
5S071, 6S1467
Ahh haa ,yes they should be brass. Oh well the hardware store is easy too.
