Points, Condenser, Rotor for Dual Point Distributor - what to buy?
Started by JWH, May 11, 2020, 11:26:16 PM
trotrof1
I use pertronix on my cars and have no problems. They start and run better all temps and the plugs, (BF 32s) are a perfect light tan color. My SUN 1115 is now a nostalgic / parts and wax cabinet.
Bossbill
I bought the correct early rubbing block points and the seller packaged them in a soft mailer. Naturally, one of them got bent in delivery.
Why would anyone package something as sensitive as points this way?
He offered to give me money back but finding these was tough so I kept them.
That's the last 'failure' I had with points ...
70 B302   6/6/70  0T02G160xxx
Pertronix and put the parts you took off in the glovebox for when it fails. I've had 2 pertronix fail. One in a Mustang the other in my Blazer. The one in my Stude has been in there for years with no problem. They can make some tachs not work right.
The Going Thing
We've had this discussion now how many times with the wives tales about Pertronix?  16 years on a Pertonix II speaks for itself.  Wire them with a 12V constant there is no issue. Even the Pertronix I.  Use their coil. You want an early failure? Ignore sound advice.
You may be able to kind of eye the point gaps, but you sure the hell can't set the dwell.  Do yourself a favor if you drive the car and dump the points.
It's a no-brainer.
trotrof1
Points are a wearing item and the performance of the car falls off gradually . On my cars it just became a unnecessary hassle. I suppose some levels of concours require them but I dont enter those. Electronics and tire technology have evolved probably the most since the 60s.
Quote from: trotrof1 on May 17, 2020, 06:54:26 PM
No judge is supposed to touch the car in concours without the owners permission. Taking off a distributor cap would be extremely irregular in most cases even with the owners permission. The requirement in concours is that it looks the part. If it pass's the look test then there is no reason to question it. The extra wire of a pertronix and the different location for that extra wire on the coil however is a very obvious tell. It is all about choices. You can choose the non original pertronix or the original points . What ever makes the best sense for each individual owners situation.
The Ford dual point distributor is a very reliable unit that was good enough for SAI to go racing with, good enough for me.
Wives tales aside, I had a Pertronix I fail and leave me on the side of the road, correctly wired, 12V, although I admit was not using their coil. In my experience, points do not fail. Start to wear and degrade performance, sure, but properly maintained and adjusted dual points just aren't that hard to do, check mine maybe twice/year and always dead on, throw in a new set every 5 years or so. The day I can't adjust a set of dual points is the day to move on...
The Going Thing
Quote from: s2ms on May 17, 2020, 11:00:47 PM
Yeah, yeah. Same ol' crap. It worked in the 60's.  Points do not last as long nor do they put out the spark of the electronic ignition. Pertronix rarely fail.
They are not prone to failure unless you run them on 6-9v . Leave your ignition switch on some time for a couple hours because you get a phone call or are working on a car with points.  They're done. You also have to set dwell every time you change them. They also require regular maintenance.
SAI used what was available in the day, it doesn't make it better and it sure the hell isn't more reliable.  Fact, not opinion.The hotter spark also helps keeps plugs cleaner with rich running engines and oil from the plugs, not to mention detonation.  Because you're stuck in the 60's with old technology that was used doesn't justify not making common sense changes that are all but undetectable.  I'm in my mid-50's. I've been working on cars since I was 14, not to mention radial and V design aircraft engines.   Not one of us are suggesting an LS or a Coyote engine change.  If you have a dust collector trailer queen, by all means why bother? If you use your car, it's not stock and drive it hard make the change. It's worth it.
If you drive your car, which I do at least twice a week it makes zero sense to stay with points.
Quote from: The Going Thing on May 18, 2020, 12:00:17 AM
+1. I agree here about points vs. electronics.
The most reliable electronics ignition to use would be the Motorcraft. That requires a separate external box.
The most concealable is the Petronix. The trigger itself is very reliable. The coil? It leaves a lot to be desired.
It's not unusual for the coils to be intermittent and diagnosing an intermittent coil is one heck of a bitch.
In their day points were reasonably reliable. The "correct" points for use in a Ford dual point have a lot of tension. Considerably more then the single point set.
This really contributes to rapid wear against the distributor cam.
Now you may not necessarily experience problems as a result BUT if after you spend probably several hours getting the dwell right on a pair of points, run them a few thousand miles and then just for the heck of it, check the dwell again.
I'll bet you credits to Navy beans that you lost about ten degrees of dwell?
That combined with a 9v yellow top Ford coil, which incidentally has it's own POOR reputation for going intermittent, you loose a lot of ignition power.
I went through this the first time I set up 48ida Webers on a 351c. To say that the learning curve was steep, is a gross understatement.
The fact of the matter was that the stock Ford ignition was not even marginal for handling the induction change.
That brought in MSD. Then three consecutive 6A MSD (might suddenly fail) brains, about the same amount of MSD coil failures.
SA raced the Ford set up with a considerable mechanical support both by it's own highly experienced (and cranky) mechanics and pallets of Ford supplied race support parts.
Don't forget either that there were other ignition systems tried by SA and even Ford. They knew the ignition was problematic but the technology of the day was limited.
There is a guy that calls himself Pantera-Electronics. Jon Haas. He has designed a completely unique ignition that eliminates the points and fires and cleans up fouled spark plugs. That was what was needed back in the day but was an "unobtainium" commodity.
Here's the thing, an MSD system WILL NOT FIRE A FOULED PLUG OR CLEAN IT UP. The P-E ignition will. Maybe there are other systems that will, but the P-E is the only one that I know of that will.
Run whatever ignition system you so choose, but there is much experience here on this forum and sharing it free of charge for you.
Wisdom is required to recognize the correct answer.
As far as I go, I've graduated from dumbass to smartass. I'm working up to wiseass. ;)
Greg
There aren't a lot of people driving their cars every day so the points do well if they are installed and adjusted properly.  I have had the pertronix and they do fail, the coils are also not very good IMO.
If you are using your car as a daily driver I would go full tilt, change it to fuel injection, MSD distributor etc...  you would be better off and it is all reversible.
Shelby's and Fords from Day 1
Quote from: shelbydoug on May 18, 2020, 09:29:20 AM
Well one thing is for sure ,you are at the top of your class.  ;)  ;D love ya man
Cobrask8
Agreed, much information here.
One other method not mentioned yet, is to use the points as a trigger for a hidden Ignition box. That way, you have the points, but they will last now just carrying a very minute electrical current. It's the high current that burns up the points. And by adding a bigger coil, more draw.
Yes, the MSD boxes have a terrible reputation, justly earned. I run a Crane HI-6 box, been great. For years, I ran a Mallory Unilite conversion, and then distributor. Very accurate timing, but now no longer made.
Quote from: Bob Gaines on May 18, 2020, 11:38:21 AM
:o
You are a wise man Professor Gaines. Much of it gained from pain, no doubt. Some though you can't spare them the pain. They need to feel it themselves.
Those with too much happiness need to feel pain so they know they are alive.
Who am I to deny that? ;D
67 GT350
Quote from: The Going Thing on May 17, 2020, 06:26:19 PM
It's a no-brainer.
Yup what he said what I said. +1 as they say.
RARE  Signature Delete
68krrrr
Have my shop installing Petronix & some other stuff currently ,there telling me the tach likeS  6v but the Petronics likes 12v I though I saw a thread about this ,what's the answer can you keep tach working correctly  & go 12v still thanks
Current
1967 GT500 #1724
Nightmist Blue /Parchment
2005 Ford Gt Midnight blue
1934 Ford Chopped & channeled
Previously owned
1968 GT/CS
"Fly low & avoid the radar"
Thanks Adam
