Are these heads original?
Started by hurlbird, May 21, 2020, 01:12:50 PM
hurlbird
looked in archive didnt see anything..... I know my block is later than the car. Is there someway to tell if the heads are correct? 1968 4speed GT 350. Nothing clear on the internet? Thanks
Greg
Take off the valve covers and you will find the date will be under it.
Shelby's and Fords from Day 1
hurlbird
DC-DD
68  350  302 heads   will say 302 4V  once valve cover is removed they will also need to be smog ports to be correct for a 4spd car.
hurlbird
smog ports obvious? I assume these are noticeable with the valve covers on?
hurlbird
answered my own question.. very obvious and I don't have them. I assume these are as common as hen's teeth?
Quote from: hurlbird on May 21, 2020, 06:52:49 PM
Look on ebay I believe there is a set on now. If you can't find any pm me .I have a set of 4 speed heads on the shelf.
hurlbird
Just found the auction.. sent you a PM. Thanks- John
