correct slop paint for 70 gt350 convert
Started by shlb69, May 22, 2020, 08:55:47 PM
shlb69
What is the correct slop paint for a May 1969 gt350 convert floors and where would the primer slop paint be on the vehicle? Photos?
Quote from: shlb69 on May 22, 2020, 08:55:47 PM
Exactly like what would be on the Boss cars which you are familiar including the same type variations .They went down the same paint line at Dearborn.
The correct slop gray and red oxide would be what was applied on it originally. Color matching a cleaned original surface from your car is the best source for color, tint and tone.  Lacking this a dark grey with a little metallic or none - tinted bluish or greenish will often pass. I've used a VW color as a base and blend from there. . Of course this is for the firewall rearward section of the follow typically. If you look to other cars as examples focus on spring 69 cars built at Dearborn rather than 70 Mustangs ;)
I'm guessing you have already seen this. It might be helpful
http://www.saacforum.com/index.php?topic=929.msg6979#msg6979
Here is the formula for the VW base color I mentioned above
M9400ID Volks L17F
   Ful-Cryl Acrylic
430-01   HS Black    822.3
430-03   HS White   1194.9
430-24   Quindo Red   1254.0
430-07   Ochre      1304.0
430-37   Phthalo Blue   1324.3
435-94   Acrylic Binder   3796.6
