Master cylinder
Started by hurlbird, June 07, 2020, 06:07:45 PM
hurlbird
thanks!!! so the fun begins with the removal of the MC and the booster. I need an extra arm and be made of rubber.  :-\
Quote from: hurlbird on June 09, 2020, 04:02:08 PM
You probably are but just in case,definitely plan on having the booster rebuilt while out.
hurlbird
Joebantelman
Getting ready top shoot the car in red oxide... Does anyone have pix of where the lift points are located. Also was looking to see what type/size washer to replicate.....
Quote from: Joebantelman on June 11, 2020, 06:12:06 PM
Kind of off thread but guess your referring to the 8 (8 visible from under the car and 4 visible from above) "dolly marks"
http://www.saacforum.com/index.php?topic=5463.msg46602#msg46602
Search is your friend :) Most of the time
Here is a picture of the front and rear frame shadows to give you an idea of the diameter of the washer/stand shadow. Small er than the width of the front frame rail attached to the driver and passenger floor panel and wider than the rear frame rail at the back of the car
If you build/create faux stands for each you will get the natural/original U shaped paint shadows from the exterior and pinch weld black out applications depending on the part of the body being painted as shown in the example below
shlb69
The Going Thing
Ford over the counter replacement masters were not painted in the 70's and 80's. Perhaps you have a replacement. I believe they were used until about 1979.
