1968 GT350 Vacuum Fittings wanted
Started by Corey Bowcutt, June 09, 2020, 03:39:40 PM
Corey Bowcutt
I am looking for 2 vacuum fittings to complete the hardware I need to install the stock carburetor.  I circled the two fittings in the pictures attached.  One is the 90 degree vacuum fitting on the carb and the other is a spacer if you will to the vacuum tree on the back of the intake manifold.  Anyone out there have spares of these they would part with?
Thank you, Corey
430dragpack
Corey,
I think I have the intake fitting, will check tomorrow.  Does it need two vacuum hose nipples, because there are some with one and some with 3-4.  Now that I think about it, I may have the carb fitting as well.
Chris
Found them both. $50 shipped for the pair if interested.
430dragpack
Corey Bowcutt
Thank you Pete. I received my fitting today from Bob Gaines and it does in fact have 4 ports. I have seen pictures that show a short loop of vacuum hose between two of the ports. This hose is painted blue with the fitting. Is this correct?
Corey
Corey Bowcutt
