Tilt away column repair
Started by Dan353, June 21, 2020, 09:39:40 AM
Dan353
Does anyone have a source that repairs or sells the parts for vacuum assembly that is installed under the dash for tilt away steering column on a 69 GT350.
Thanks.  Dan
kasearch@ix.netcom.com
Tony Augustine <6t8cougarguy@gmail.com> .  he did my column and has sources for parts
I have some 69 (black canister) and 68 (white cansister) vacuum /relay assemblies on the shelf if you hit a dead end. PM me if interested.
430dragpack
What is the correct door pin switch that activates the relay look like and part number?  Is it another white plastic style with Autolite or have the metal face/mount tabs? If it's the metal style, what is the finish, phospahte or silver cad?  Also if it's the metal style, does it have a round plunger or more flat face plunger?
Krelboyne
C6OZ-13713-? is the number for the door jamb switch 1967-69. Black button and the metal surround.
Quote from: 430dragpack on June 25, 2020, 10:41:42 AM
Looks like this example I grabbed from ebay just now. The finish when new is typically brighter then the oxidized finish on the example. Plunger has rounded tip.There are no mfg markings that can be seen.
430dragpack
Quote from: Bob Gaines on June 25, 2020, 11:02:26 AM
That switch is the C7ZZ-13713-A, I confirmed it with him this morning and would work in place of the C6OZ-13713-A.  They look the same, function the same, the C7 has a slightly larger hole 29/32 vs. 7/8 for the C6.   That's why I was asking about this. Some of the C6's have the round plunger, some don't.  They both have the large female bullet connections as well.
Quote from: 430dragpack on June 25, 2020, 11:18:21 AM
I have not ever seen a original tilt switch that did not have the round plunger end.
JohnHouston
West Coast Cougar has a lot of this stuff.  Nice folks to deal with.
John
Krelboyne
Those are two different switches that get confused. The C7ZZ-13713-A switch has a longer plunger or button. This switch is mounted to the side of the tilt column on a 1967, not in the door jamb. Also has the squared edges on the metal ring.
Has anyone else seen the switch with the squared edges and longer plunger on 68'and 69's?
Corey Bowcutt
Quote from: JohnHouston on June 25, 2020, 01:34:03 PM
John
These are great folks to work with.  Four years ago I bought a complete under dash tilt steering module from them that works perfectly in my car.  I was talking with WCCC a few weeks ago and the guy they had there that serviced these is no longer with them.
Black, round head, metal bezel
Quote from: Coralsnake on June 25, 2020, 05:34:11 PM
What about length and if cut squared edges vs round?
Two straight edges across from each other on sides of bezel
