Bj/Bk Carbs Trick Kit? Pic Gauge pod pictures needed
Started by Kent, July 09, 2020, 11:04:25 AM
I spent 30 seconds at https://google.com to find this answer:
https://www.summitracing.com/search/part-type/throttle-shaft-service-kits/carburetor-manufacturer/holley
Quote from: Kent on September 09, 2020, 08:29:08 AM
Does somebody know where I can order the correct bushings for the throttle blades? Is there anything else I need which is not in the trick kits?
Drew Pojedinec
Mr Royce,
You need the reverse piloted reamer as well for those.
They work well when needed.
Kent
Thanks I thought there was a more high quality kit, I cant remember where I have seen it it was a box with easily 50 bushings and 2 or 3 reamer. Thats the one I´m looking for.
Kent
Drew Pojedinec
Quote from: Kent on September 09, 2020, 03:25:53 PM
somebody ever tried these?
https://www.ebay.de/itm/Holley-QFT-AED-CCS-Nylon-Throttle-Shaft-Bushings-1013-490-015-Thick-Stock/170709015817?epid=1017835785&hash=item27bf0cdd09:g:F1AAAMXQTghRSTFk
Mr Kent, those are just for the secondary throttle shafts.
There are teflon for the primary as well, but honestly, they make too much resistance with the thin gauge old Style return springs.
Having spent my working life doing aircraft sheet metal for 20 years I have a ton of experience using reamers and the reamers themselves. One needs to know how to properly ream a hole. Just owning a reamer won't help much.
Quote from: Drew Pojedinec on September 09, 2020, 02:53:01 PM
Mr Royce,
