What did you do to your '67 today?
Started by rmarble57, July 18, 2020, 04:27:34 PM
Warmed it up by scaring the local small children and pets,then changed the oil... ;)
Side-Oilers
Sounds entirely reasonable!  Hope you laid down some new black lines on the pavement too.
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
Quote from: 557 on May 25, 2022, 09:57:05 PM
taarent you are a wild and crazy guy  !
Lfino
Out of the garage and onto the street for first time since 71. Took  it to the gas station ($85) then about a 4 mile shake down with a chase vehicle behind.
No leaks or overheating. No brake lights.
Small fix!
557
Lfino
Quote from: Lfino on May 26, 2022, 12:54:57 AM
Small fix!
Love it !
Took ours out yesterday also, a one hour run, half tank a gas later....PRICELESS
Enjoy it !
greekz
Hopefully, it is the brake light switch or loose wire, not in the turn signal switch.
SFM 6S1134  '67 GT-350 #2339
Lfino
Just checked it out.
Forgot to install the switch! Oops.
tonys_shelby
Getting ready for Carlisle, painting the pan bolts that got scratched up when changing the gasket. Wiping down underneath.
greekz
Quote from: Lfino on May 26, 2022, 12:55:53 PM
I like those simple fixes.
Lfino
Quote from: tonys_shelby on May 26, 2022, 01:19:11 PM
Wish I had a lift!
Haven't gotten the bottom dirty yet,  but I don't look forward to crawling around under there.
Wish I had a lift
S412gofast
Well Yesterday, we Dyno'd the 289 hipo engine for our restoration of GT350 #1341.
Engine built by Carlquist Competition Engines in CT.
Dyno set up
37° total advance, 1.75 BBK headers, .016 lash
292hp @ 5500rpm (ran out to 6000rpm, 291.7hp)
302 ft•lbs @ 4400rpm
Specs
Engine Balanced
Cam: Stock Ford hipo
Stock C7 hipo heads no porting, still have bump in exhaust ports unique to C7 for thermactor provisions.
Heads fitted with 1.50,1.84 valves did this as hardened seats were installed.
Bore .030
Intake: Orig Shelby S7MS 9424A, port matched to heads.
Carb: Orig Shelby 3259 715cfm
Distributor: orig FoMoCo dual point.
Carlquist modified the slot in mechanical advance plate. Welds it up and machines to .380. This allows for 18° init and 36-37° total timing.
greekz
Cool! Nothing quite as nice as a good running hipo!
