Hood screens
Started by Dan353, July 18, 2020, 06:27:48 PM
Dan353
Does anyone know how the  screens where originally attached to the hood were they glued or screwed on?   If you would please post pictures.   Thank you
Dan
Believe you will find that typically it depended on which screens your asking about. Might even help if we knew when your car was built (in this case converted as best you can tell)
Forward screen examples
Rearward screen examples
Dan353
Jeff,  thank you for the pictures.  My car was built January 6 1969  I don't know when it was converted to a Shelby GT350.  I'm guessing from the pictures that the rear screens are glue only and the fronts are glued and have the two fasteners.  The screens on my car look like the pictures but are loose (one forward and one of the rears has half the glue missing) and need to be secured.  Is there any special tricks to installing them? It looks pretty straight forward. Thanks again for your help.
Thank you    Dan
Quote from: Dan353 on July 19, 2020, 01:51:33 PM
Thank you    Dan
Fronts don't use glue. Two screws in the front and two screws in the back just like in the picture.
Dan353
#4
Thank you for the information Bob who ever installed my front screens used silicone.  What material was used to glue in the back screens?
Dan
I believe its the same ted red bonding agent used to attach pieces of FRP together. (KR plenum glue)
Dan353
 Sorry but I don't know what a Ted bonding agent is or what FRP stands for.  Is there a place to purchase these materials?  Or what else can be used to secure the screens
Quote from: Dan353 on July 21, 2020, 08:17:04 PM
JB weld epoxy.
Pete is correct rear screens are bonded on same reddish brown sealant like 68 KR ram air chamber that was added to 68 Shelby  hood.
"Ted" should have been red,  my apologies
FRP = fiberglass reinforced plastic ( shelby fiberglass)
http://www.thecoralsnake.com/FRP
JB weld can be tinted for the occasion.
Quote from: Bob Gaines on July 22, 2020, 11:42:49 AM
did they bond them before or after the underside black paint was done? Gary
Quote from: shelbymann1970 on July 22, 2020, 02:50:42 PM
I believe after.
Quote from: Special Ed on July 21, 2020, 10:12:29 PM
Guess what is most important for the viewers is what finish is visible to the eye once the hood is complete and on the finished vehicle :)
Believe that is what shelbymann1970 is asking about.
On the unrestored examples I have pictures of and the ones I've owned I didn't and don't see the almost red oxide colored sealant visible on the finished product/car. Will look through the collection again
Dan353
I just wanted to say thank you to everyone for the information
Dan
