Is this the correct position for brake booster fitting?
Started by tonys_shelby, July 27, 2020, 10:47:39 AM
tonys_shelby
Not sure if I need to rotate the fitting more and have the tube be more towards carb.
Your image rotated and one with what maybe the answer to your question...hope this helps.
Quote from: JD on July 27, 2020, 12:25:24 PM
FYI the positioning of the vacuum tube should be the only thing copied in the example picture. Other details are historically incorrect.
oldcanuck
You mean that 5/8 inch open end wrench isn't factory ?
Sorry Guys,  I couldn't help myself.....
Bob
Knoxvegas, TN
The Going Thing
Do you have an air conditioned car? Automatic  trans?
