67 GT500 Thermostat housing
Started by shelbydoug, March 17, 2018, 06:13:15 PM
Is this supposed to be painted or natural as cast? I forgot and I am seeing both ways on engine pics.
I know I have blue paint on the intake manifold where the mask leaked right in that area.
Quote from: shelbydoug on March 17, 2018, 06:13:15 PM
Painted in place on the aluminum intake.
acman63
Going to start calling you Mr Concours  Mr. W
SAAC Concours Chairman
Quote from: acman63 on March 17, 2018, 08:56:57 PM
You'll never know when I will show up. You're all safe in a group but don't wonder too far away?  ;)
Who would have thought. ;D
So in theory, "we" can take this thermostat housing, "machine off" the cast in plug and paint it. Then "walla!" we have a 67 housing?  ;D
Quote from: shelbydoug on March 18, 2018, 08:54:47 AM
I am assuming it has the "thumbprint' divot on the other side . If it doesn't there are others that do. I would also machine off the C8 engineering number too. Then you would have something similar not exact.
Until someone makes some new ones, it's a consideration. The casual observer just sees the additional casting for the vacuum tree.
The casting numbers are so fine that they tend to get unnoticed.
It's just going to be the Head Judge that needs to have his glasses hidden?
At $35 vs. $500, the difference makes the consideration valid. In fact, they are so rare, I may have to buy an entire car to get the part?
I do think I remember reading of a limited run 5-7 years ago?
Quote from: shelbydoug on March 18, 2018, 11:38:57 AM
I thought Scott Drake made a copy of the C7AE-A thermostat housing? It was in their 2016 Scoot Drake product catalog at 24.95.  It isn't perfect but at least as good as machining the one in your picture and without all of the trouble.
Quote from: Bob Gaines on March 18, 2018, 11:56:08 AM
I do think I remember reading  of a limited run maybe 5-7 years ago?
It is not in the online catalog. Maybe he sold out and isn't making more?
Ah! That is the picture of the Scott Drake C7AE-A thermostat housing that I posted above.
Quote from: shelbydoug on March 21, 2018, 08:57:04 PM
What a shame . I know a couple years back they had a version without the vacuum fitting stub that was meant for 67. At least it is not expensive, so you can hack away.
Quote from: Bob Gaines on March 21, 2018, 10:26:20 PM
Yes. :'(
In fairness, they are no longer listing that housing in the online catalog. It is just identified currently by the C7AE part number by his current dealers that still have a few.
I'll call 'Drake' later and see what they say about having any of the 'original' batch left. The people I talk to on the phone there tend not to know any more then I do though.
Do you have a picture or can you scan that catalog and post the picture here?
I'm wondering if that picture you are looking at is of an original they were showing before they decided how to make the 'reproduction'?
Machining off the bump on the current one, which is a $20 part, then heavily sandblasting it to get a uniform 'cast' finish seems to be a reasonable alternative?
It does depend on what the internal dimple looks like. Ideally there is none on that 'plug'.
Bob. Jerry @ DrakeScott says the one with the casting bump IS the only one that they ever offered.
He does say that that plug is solid all the way through and can be machined off without needing to be welded up.
That sounds like Plan A at the moment.
