GT350 build date 1/8/69 Under Hood, doors and trunk stickers
Started by SChatman, September 04, 2020, 11:45:42 AM
SChatman
Looking for pictures with correct placement of stickers and if possible close ups so I'll know which are correct, tire pressure sticker is a big question because I'm not seeing one for the E70-15 tires my car is supposed to have
Thanks in advance.
Quote from: SChatman on September 04, 2020, 11:45:42 AM
Thanks in advance.
The E 70 15 sticker is available .It is the same one used on 67 and 68.
For your other decal/stickers. Body style might help just so we can provide the closest matching original examples
TOBKOB
1969 GT350 owned since 1970
Here is a start from memory for a Jan built GT350 fastback
Interior
Tire pressure stickers in the glove box and Mustang one of the drivers door. For that period most likely the C9ZA-B version. You already have pictures of the glove box Shelby one
Trunk
Trunk lid - Space saver, Federal Highway and jacking instructions
Jack - small white one on the side of an arm
Engine Compartment
Air cleaner - Cubic inches and AUTOLITE filter
Drivers side shock tower - Timing/Emission decal
Below the timing/Emissions is typically the Service Spec sticker
Engine - Engine ID  torn  from roll so the ends have jagged straight look
Passenger forward  inner fender panel - Battery inspection Filled out with round inspector stamp
Voltage regulator - red paper label/tag around the condenser pig tail. Held in place with two staples
Spark plug wire ID stickers -
If you have air conditioning there are more decals related to those items
Of course throughout the car wire looms with have ID and assembler labels
And also a bunch of the small square inspector check stickers in the engine compartment and interior
SChatman
Thanks Jeff, Ive attached this decal do you know where it goes? NPD says it belongs with a Group 24 battery.
Quote from: SChatman on September 05, 2020, 10:47:38 PM
Not Jeff but a GT350 in 69/70 could come with a 24 F battery or a 27 F battery . If your car came with a 24F then it would go on a original  or reproduction of original battery. I wouldn't put it on a later Motorcraft or aftermarket battery.
SChatman
Thanks Bob, I have a generic plain battery with the  Faux battery top cover on it.
