1967 GT350 air cleaner decal
Started by KShane, September 04, 2020, 01:38:45 PM
KShane
What is the correct air cleaner decal for a 5/12/67 SA completion?
The primary one is the COBRA dark blue on off-white, (bottom one is good reference for original - might have been paper) there is also another smaller "Ford" sticker about 180 degrees from it on top of the chrome lid.
T-Bone68
Should the Autolite sticker be there, 180deg from the COBRA sticker?
Pictured in this article, that explicitly says you can share this link in forums.
https://www.diyford.com/shelby-mustang-history-1967-gt350-gt500-longer-shelby/
Vernon Estes
Junk dealer and the oldest young guy you will ever know.
Quote from: T-Bone68 on September 04, 2020, 04:41:30 PM
The article has useful and interesting information but also has some information that is not accurate. You should have the Cobra sticker in the front and a small sticker in the back on the 67 GT350. NPD sells a repro of the small sticker on pg 325  . Part number D-112. The Autoite sticker and or the HIPO sticker were not typically used. FYI the Cobra sticker was also used on the 428 MKIII Cobra single four barrel Hipo type aircleaner .
Quote from: Bob Gaines on September 04, 2020, 06:11:29 PM
The article has useful and interesting information but also has some information that is not accurate.................
+1
Yes even includes/continues to repeat, the urban legend that "KD" = "knockdown"   ::)
T-Bone68
Thanks Bob, Jeff, JD... Your advice is always appreciated.
And Vern... already bought one of yours. :)  thanks!
The article has useful and interesting information but also has some information that is not accurate. You should have the Cobra sticker in the front and a small sticker in the back on the 67 GT350. NPD sells a repro of the small sticker on pg 325  . Part number D-122. The Autoite sticker and or the HIPO sticker were not typically used. FYI the Cobra sticker was also used on the 428 MKIII Cobra single four barrel Hipo type aircleaner .
I think you meant to type D-112 for the C7 ('67) part,
https://www.npdlink.com/product/decal-part-number-air-cleaner-c7zf-9600-f-located-at/125599?backurl=search%2Fproducts%3Fsearch_terms%3DD-112%26top_parent%3D200001%26year%3D
not D-122 for the D1 ('71) boss 351 part?
https://www.npdlink.com/product/decal-air-cleaner-autolite-replacement-filters/125609?backurl=search%2Fproducts%3Fsearch_terms%3DD-122%26top_parent%3D200001%26year%3D
not all of the images are of 100% representations of "correct", those are hard for authors to find.  Some of the content maybe correct for the point being illustrated, but not necessarily for all the content that is in the image.
This is why guys like Bob, Jeff and others caution just duplicating "show cars".
Nice restorations may not always be accurate - if that is what you are looking for.
Quote from: JD on September 05, 2020, 08:26:33 AM
Thanks JD . I amended my typo.
cascade-classics
#10
I was going throug the SAAC Convention 43 judging rules for the 67 and on page 8 it states under Engine Compartment Decals "GT350 - Autolite Spark Plug Decal and Cobra Power by Ford decal on air cleaner"   Is this an error? I went with the D-112 (Part number) decal as you specified, not the Autolite Plug decal.
Quote from: Bob Gaines on September 05, 2020, 01:13:02 PM
In the above post(s) Bob adjusted to the D-112 part number.
Link:
https://www.npdlink.com/product/decal-air-cleaner-part-number-c7zf-9600-f/125599?backurl=search%2Fproducts%3Fsearch_terms%3DD-112%26top_parent%3D200001%26year%3D
Image of correct sticker is the top one in Reply #7 above, and it is shown on the lid with the COBRA sticker 180 degrees away in the second image in reply #1, as Bob G stated.
And yes, I think the sheet maybe incorrect
[quote cascade-classics]
I was going throug the SAAC Convention 43 judging rules for the 67 and on page 8 it states under Engine Compartment Decals "GT350 - Autolite Spark Plug Decal and Cobra Power by Ford decal on air cleaner"   Is this an error? I went with the D-122 (Part number) decal as you specified, not the Autolite Plug decal.
Quote
cascade-classics
#12
Quote from: JD on December 16, 2020, 01:10:59 PM
Link:
Quote
Thanks JD.  I made the same typo!  I used the D-112 not the D-122.  I corrected my original reply.
Jbrooks
Thanks for all the information on this post.  I live learning something new about my car, even if it means that a new parts order is needed.
I will be correcting this on my car, as I have had the wrong stickers on my car (came that way, but correcting it now).
67 GT350 #2260
"If you ain't first, you're last"
Jbrooks
If the Cobra sticker is at the six o'clock position on the air cleaner, what position should the smaller air cleaner sticker be placed?  I saw it mentioned that it should be 180 degrees, but the picture above shows it offset a little (like the 1:30 position). Searching Google, I see it at both positions as I go through the pictures.
Thanks in advance.
67 GT350 #2260
