date code on block
Started by 427hunter, September 10, 2020, 10:05:54 PM
S7MS427
Quote from: 6R07mi on September 17, 2020, 04:38:19 PM
Cleveland would cast the block & heads ( my casting date late Oct 65 ) and then assemble the engine ( mine Nov 4, 65 ), the stamped date & shift ID on the oil pan rail face.
Interesting.  I know where to find the assembly date (mine is 5L3, one day ahead of yours) but where is the shift ID located?
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
Quote from: S7MS427 on September 18, 2020, 07:33:30 AM
At the end /included in the machined date on the oil pan rail
DennyD
So the letter "B" at the end of each of these examples is an indicator of the work shift in which the machine work on the block was completed, and not an inspectors mark. Correct?
6 A 26 B
and
5 D 28 B
Quote from: 6S1568 on September 18, 2020, 07:12:16 PM
6 A 26 B   and   5 D 28 B
Believe that is the current thought. Only finding A's and B's so far
There are a fair share of other numbers. letters and symbols on the rail also. Those may indicate checks, confirmations and inspections of the block
S7MS427
Quote from: J_Speegle on September 18, 2020, 07:26:47 PM
I'm guessing that A would be 1st shift and B 2nd shift?
Roy Simkins
S7MS427
After retrieving my block from another state, I have located two sets of date codes, the a fore mentioned 5L3T on the front of the block and a 5L3E on the oil pan rail below the block casting number.  Any opinions as to what the "E" represents?  Thanks.
Roy Simkins
Quote from: S7MS427 on August 27, 2022, 09:39:06 PM
Had not see/hear of an E yet so thanks. If it identifies not the shift but the week a fifth week is fairly rare annually
If it was worker like used on the assembly stamp then we would see more variations used.
Have not seen anything in any Ford manuals or documents explaining the machining date as there is for the assembly date
