Which Daytona Coupe is this ??? Daytona letter on the front fender ...
Started by Szabo, September 19, 2020, 07:45:37 PM
Quote from: 68countrysedan on September 20, 2020, 12:19:29 AM......Finally, look at the wheel balance weights. Looks like a lot of weight was added. What's up with that?
Sand cast wheels, a little bit of sand gets knocked off the mold before it's poured and/or variations in machining. I saw one that when mounted the rim and tire ran true but the center moved about 1/16 of an inch when you watched it rotate.
Quote from: Szabo on September 22, 2020, 02:37:40 AM
Only the Number ?
Can you explain why you think it was 2299 in the LAX Pic ?
Greets Stephan
windshield on 2299 is taller  than other 5 coupes
