69 GT350 Underhood Vacuum Diagram
Started by SChatman, September 20, 2020, 01:27:47 AM
SChatman
Any thoughts on an under hood vacuum hose Diagram for a car with A/C, PS, PB,I've got a 350 with an FMX and have looked through several diagrams ( Biue Book, Break away steering supplement  but haven't found one that has everything I'm looking for.
Quote from: SChatman on September 20, 2020, 01:27:47 AM
try the concours Mustang forum. I believe at one time(could have been SAAC Forum Version 1) where Jeff Speegle posted some pics  of a GT350 engine dressed out and I think it was an AC car. Gary
Here are some pics I have. I am not sure if these help. The double pics were taken off of a friends 69 GT350 Gary
Disregard things like "front" and "caution fan". pics all from the 90s. Gary
SChatman
Thanks guys, the hoses that I canT. find a diagram for are the breakaway steering wheel under the hood hoses, where they go to the vacuum canisters and onto the vacuum treat the back of the engine. Also which nipple does the vacuum line from the automatic transmission attach to I assume on the vacuum tree also at the back of the  engine.
Quote from: SChatman on September 20, 2020, 11:12:06 AM
I thought you were looking for Engine vacuum line setup. Do you have the stand alone tilt schematics book that is available aftermarket? The 68 schematic for Shelbys I would think would be similar and it shows the whole setup even with air. Having a 68 and 69 setup I have no reason to believe the actual tilt wheel wiring or how it was plumbed is any different. Gary
SChatman
Yes I have the tilt supplement but it doesn't tell you much as far as vacuum line routing.
Quote from: SChatman on September 20, 2020, 06:37:26 PM
Not sure what "supplement" you're referring to. In the 1969 wiring and vacuum book the Mustang tilt diagraph is shown with the routing (pg 2-V3) and on another page the power ventilation as well as AC vacuum routing. The challenge is that they do not show or reference how things differed when two of these are installed on the same car. The routing from the swing away vacuum pod to the firewall grommet I don't think I have a picture of since getting a good picture would be difficult with everything installed.
There is a routing diagram on page 2-V2 showing the routing of a system (generic as far as engine) with AC, cruise and tilt though it has only a single reservoir.  It also shows a 3 way and a four way T's being used as well as the two into one round check valve we are familiar with
