Waxing the Hertz before winter
Started by deathsled, September 28, 2020, 08:26:04 AM
deathsled
Engine revving to disturb
BGlover67
Any chance I can get you to do my cars next?  :)
Brian R. Glover
Doug C
deathsled
I would be happy to do others cars (waxing with the P 21 S carnauba) if you are in the proximity of Chicagoland.  It's very rewarding to do good work on something.  I don't do orbital polishing or the like.  Too dangerous and it wears down the paint.
You forgot the door jambs and under the hood.
deathsled
Quote from: 98SVT - was 06GT on September 28, 2020, 09:19:10 PM
That's a 10-4.  I will address that oversight forthwith.
CSX 4133
Quote from: deathsled on September 28, 2020, 08:23:52 PM
Sometime next spring you should after washing your car, try a Iron remover prior to waxing, etc. It removes the small imbedded particles from pollution, exhaust and brakes from paint and leaves a totally clean surface. You will notice how much better your waxing will come out. Oh, and a Random Orbital polisher is very safe, operated correctly, and with the correct pad brings out added luster. I use several coats of sealant prior to several coats of Carnuba wax, even white cars will glisten.
Very nice Shelby by the way, I just purchased a red with white stripe '66 myself, looking forward to enjoying it this fall.
