Radiator Date Code
Started by ramrace, March 21, 2018, 12:41:58 PM
ramrace
If you car was received at Shelby American 6/65 and your radiator date code is 7/65, how many points deducted?
If it is stamped with M rather than G, how many points deducted?
Bigfoot
For starters. It might be that it differs depending on which class you are entering.
RIP KIWI
RIP KIWI
Will give this one a stab
Depends on the team, what class your entered in and judges.
Date codes are not "used" within the body of the judging rules - the individual sections such as radiator or distributor for example in the Concours class
Consider that it the radiator is the correct style (automatic or manual), straps are the same as the originals, core is like an original, finished correctly..... then anticipate a small percentage of the overall points in that section since your radiator would be only partially incorrect visually from original.
Have to leave room to reward the owner/builder that got it 100% correct
Quote from: ramrace on March 21, 2018, 12:41:58 PM
To add my 2 cents ,the "M" vs the correct "G" is more relevant in most cases then the date. That is like having a incorrect paint mark , ink stamp on a radiator hose or starter etc. The correct one gets a pass or no mention but for the incorrect expect push back and or a deduction. The premier /DIV I, Thoroughbred ,Heritage Diamond venue class's expect the correct date code too.
ramrace
Looks like this will be my radiator.
Quote from: ramrace on March 23, 2018, 11:51:46 AM
If only you could make the "F" go away.
kingchief
This would be better!
Steve
SFM 6S406
