Hipo 289 Pulleys
Started by csxsfm, October 13, 2020, 11:21:13 PM
csxsfm
Are there any Ford two groove 3/8 belt water pump and crank pulleys suitable for an early Hipo 289?  Appreciate any info available.  Thanks.
Quote from: csxsfm on October 13, 2020, 11:21:13 PM
There were no two groove pulley's used on 66 GT350's from the factory. With that said could you explain why your question?
csxsfm
"Back in the day" I threw my belt in an SCCA race with sad results.  Always wanted to have some redundancy.  No concern for accuracy for a particular car.  Just OE Ford.
6R07mi
as I recall the A/C option had dual groove, you should check diameters through!
regards,
jim p
Quote from: Bob Gaines on October 13, 2020, 11:58:42 PM
     +1 Never on a GT350 except maybe the 4 convertibles with air .They required a modified balancer per Jim Cowles as the A/C pulley is a bit larger in OD.
   Double groove pulleys from a standard '66 289 with smog and power steering should work. My MPC is at home so I can't check it now.
Quote from: gt350hr on October 14, 2020, 01:09:49 PM
Randy it was not a modified hipo balancer but a special made for the application aluminum crank pulley .
    Thanks Bob,
       The only one I had seen in person was the green one back when Joe Wallace owned it. I guess it was the '67 that had the modified balancer. He probably still has it for sale.
  RG
