SPEC Rearend Chunk
Started by 67GT500#1594, October 14, 2020, 07:29:12 PM
67GT500#1594
Everyone,
I'm trying to find more info out and possible asking pricing for a SPEC chunk I've recently acquired. I was elated as can be to find one FINALLY and this one is in great shape! It is a 3.89 ratio (GT350 I believe?) but it also has a Trac Loc installed too. The SPEC casting is upside down?
I've also since found the original SPEC case for my car!! It's a 3.50 ratio "open" unit. The previous owner took it out and thought it was junk because it had no posi!! It sat under a bench for 28 plus years!
I'm gonna sell the 3.89 SPEC unit as I no longer need two. What's a realistic price to ask? I've only seen a few through the years even offered for sale and NEVER one in person. Are they really THAT rare and hard to come by? Appreciate any help here.
Regards, Matt
Greg
They are hard to find, I have seen them and sold them at $1500 but I have also seen them up to $2500.
Shelby's and Fords from Day 1
Kent
I bought some of those all were between 1500-2250$ send me some pics of yours you want to sell.
There are 2 versions of the spec case with drain plug and without.
Quote from: Kent on October 15, 2020, 03:32:05 AM
Those are the asking numbers I heard as well but you won't get the exact number until you "sit down" to nail down a number.
These things are rare enough to just "demand" a certain number and a "take it or leave it" position.
I know as a fact a few holding SPEC cases and not openly acknowledging that. They really feel that even at around 2 thousand, the things could "double" much like date correct big blocks are/did. So there is no knowing how high is up.
      Back in the '70's no one gave a hoot for the unique "SPEC" marked cases, and we would sell-off those as marked first, as being considered some sort of substitute standard unit for the otherwise typically marked, "good" ones'!          :o
      Oh well, not the first mistake I ever made.        ::)
Tinface
Guys—
Is what Matt is selling the center section for the rear end that is the limited slip mechanism that a 1966 GT350 owner could have purchase around that time?
Mark
Greg
Quote from: Tinface on October 29, 2020, 08:37:30 PM
Guys—
Mark
Mark, no the SPEC cases were used on 67 GT500's.
Guys—
Mark
Matt is selling something that would have come in a 67 Shelby not a 66 . The unit would not be something that would be easily ordered in the 66 67 time frame.
Quote from: Greg on October 29, 2020, 08:56:23 PM
Guys—
Mark
Actually the 67 GT500 typically had a spec case. It was 67 GT350 that it was typically not used in.
Tinface
The SPEC cases were used in three vehicles - the 1967 Shelby GT500, the 1967 Fairlane 427 (W or R code) and the 1967 Mercury Cyclone (W or R code.)
If I had one I would want $2500 for that assembly provided the innards are greasy not rusty.
    The SPEC case is nothing "special" . The "run" was cast at Ford's specialty foundry most often used for short run , pre production prototype parts. The SPEC tag has been used on LOTS of parts. Water pumps , cylinder heads , intakes ( cast iron only) are some of the parts I have owned with it. I have yet to discover the reason that foundry was used but C4AW-B case production resumed at the Detroit Iron Foundry (DIF) on the castings in late '67 after the end of SAI production."My" guess is about 4,000 cases were cast there in '67 only. They are ONLY "correct" for the production vehicles Royce listed .
Quote from: gt350hr on October 30, 2020, 12:17:05 PM
Nothing special except around a $2,500 price to buy a case.  :o
I'm SO glad I found mine! ;)
Quote from: Royce Peterson on October 30, 2020, 08:54:02 AM
And early 68 gt350s
