1970 5 spoke rims
Started by Greg, October 20, 2020, 09:37:18 PM
Greg
Did I have this correct...
69's were riveted centers
70's weren't
If this is correct, how were the 70's center attached to the rim?
Shelby's and Fords from Day 1
Quote from: Greg on October 20, 2020, 09:37:18 PM
70's weren't
He have it partly right. When the wheels were first issued the centers were glued and then press fitted into the rim . A problem developed on some that was cause for a recall. Many didn't get changed out however. The new and improved wheel had the center riveted in place to the rim.
It was not a 69 vs.70 wheel thing.
Greg
Thank you the education Bob.
The rivets were one of many things they tried. The bigger issue was the chamfer on the lug holes and lug nut engagement. Several dealers reported wheels coming off.
Thats never a good thing.
Some reproduction lugnuts are made out of stainless steel to eliminate the tendency for the chrome to crack on the steel lugnuts when putting torque on them. If you use lugnuts made out of stainless steel you have to continually check them because they have a tendency to loosen up.
