1966 brake proportioning valve
Started by EdwardGT350, November 14, 2020, 09:38:23 PM
EdwardGT350
original brake proportioning valve is leaking.
is there a rebuilt kit available?
who is rebuilding them?
what are the correct finishes?
pix would be nice to see.
tia
ed
1966 GT350 6s1761
hertz350
Kits are available at VA Mustang and NPD and others. The original color on many of them was grey. I have seen some painted black and some left natural. White Post Restorations rebuilds them and in the process re-sleeves them.
Quote from: hertz350 on November 14, 2020, 10:04:54 PM
Some early 65 GT350's were gray . Later 65 and all of 66 were painted black to identify the special adjusted C5ZX (Shelby) proportioning valve. None were natural whether on regular Mustang or GT350.
hertz350
Thanks for clearing that up. I guess the natural ones I have seen must have been rebuilt.
greekz
Quote from: Bob Gaines on November 14, 2020, 10:16:17 PM
Would that be flat or semi-gloss black?
SFM 6S1134  '67 GT-350 #2339
EdwardGT350
is white post the preferred rebuilder?
any feedback on Karps brake service in upland calif?
1966 GT350 6s1761
Quote from: greekz on November 15, 2020, 11:05:11 AM
They all appear to be semi-gloss that I've seen. Very popular and available at the time and and might have provided slightly better protection against the rust
Brant
-Brant
EdwardGT350
where do they tend to leak? mine is pretty dry.
i only notice moisture on the floorpan seam(under car) where paint started to peel. im now starting to think its weeping from a previously bad master cylinder.
1966 GT350 6s1761
greekz
Quote from: J_Speegle on November 15, 2020, 02:38:03 PM
Thanks Jeff.
Quote from: EdwardGT350 on November 15, 2020, 04:20:24 PM
Believe they are designed so that when the seal leaks the fluid is directed through a channel and out the bottom, pass the large thick rubber band sort of seal that goes around the cylinder. I posted a engineering drawing/drawing a month or two back if you want to do a search. Might have cropped it but if you want might be worth a look
ramrace
Can anyone recommend someone who will sleeve the valves?
Quote from: ramrace on November 16, 2020, 12:10:03 PM
As already mention White Post is one .Apple Hydraulics is another.
EdwardGT350
do the valves leak when car is just sitting or does peddle pres need to be applied?
1966 GT350 6s1761
