1969 GT350 Parts
Started by nightmist67, November 19, 2020, 10:41:26 AM
nightmist67
I am looking for the following original good used/NOS parts for a 1969 GT350 built in late December 1968:
1.  Original steel/fiberglass tail light panel
2.  Air conditioning compressor
3.  351W thermostat housing vacuum tree fitting
4.  Rear fender mounted antenna kit (round base?)
5.  Steering wheel wrap kit
cbrown
I have had the straps made just need to have them plated. and have the correct hardware ( Clamp , Screws and nuts.)  Hang loose i should have in week or 2.
chris
nightmist67
Thanks to all.  So far, I have the A/C compressor, antenna, and vacuum tree fitting.
I also need a correct vacuum/pressure gas cap for a car that underwent the vented gas cap recall.
Quote from: nightmist67 on November 21, 2020, 11:40:48 AM
The GT350 were not part of the recall just the GT500. It was not necessary on the GT350. The GT350 used the vented cap with no issues . If it makes a owner feel better is one thing because it is their car and can do whatever they want however understand that The gas cap recall modification done on a GT350 would not be considered historically correct and be deduction in concours for example .
nightmist67
 Thank you for the clarification.  I was under the impression that the car was subject to the fuel vent recall campaign since it was so reported in the Shelby Registry notes regarding the car's maintenance history.
