C6 neutral switch question
Started by Shelbypat, November 23, 2020, 08:43:52 AM
Shelbypat
How the neutral switch harness hold on his way up to the connecter? (Surely not with tyrap to the brake line.)
If my memory is not bad, there is a P clamp hold the harness at the upper bolt of switch. What kind of  clamp is it ? Like the one on valve cover ?
Is It avalible ?
TKS
Patrick
The harness comes forward over the neutral switch and through the vinyl lined clamp attached to the forward bolt securing the switch to the transmission. Yes that clamp appears to be identical to the clamps used to secure the engine wiring harness on top of the driver side valve cover.
Quote from: Shelbypat on November 23, 2020, 08:43:52 AM
Is It avalible ?
TKS
Patrick
Shelbypat
Thank you. And how about the wire for the light coming from the shifter. How does It  hold aside or Along the floor to the connector ?
Patrick
